GE HealthCare - Signa Ovation 0.35T
The GE Signa Ovation 0.35T MRI system is a state of the art, open MR imaging system designed to provide maximum patient comfort.
The GE Signa Ovation 0.35T MRI system's open, patient-friendly design measures 142 cm (41.5 feet) pole to pole with 16 inches of vertical clearance, to accommodate even larger patients without the trauma of closed quarters. The GE Signa Ovation 0.35T MRI is equipped with a patient table rated to 225 kg (500 lbs) that can swing 25 degrees to either side and laterally an additional 12 cm (5 inches), an integrated transmit/receive body coil and an optional XL body surface coil. This design allows optimal positioning of off-center anatomy and optimizes access during interventional procedures.
FORUMSView All (9)
0Replies3 years ago | Code error #11026 Hi, if anyone knows what the error 11026 means, please let me know because I have to fix the mri. MRI GE OVATION 0.35TReply |
2Replies7 years ago | GE SIGNA OVATION, Service Manuals I need service manuals for a Signa Ovation .35T MRI (2011) Please advise BestReply |
1Reply7 years ago | User manual I d need user manuals for Mri Ge Signa Ovation 0,35TReply |
SERVICE COMPANIESView All MRI Systems Companies
- Real-time interactive imaging at 3.5 frames per sec
- Robust gradient system (19mT/m, maximum SR46T/m/sec)
- 2D slice thickness of 1.4mm - 20mm
- 3D slice thickness of 0.2mm - 20mm
- Open, patient-friendly design
- Maximum patient weight of 225 kg (500 lbs)
- 4 (8 quad channels) independent high bandwidth receivers
- Fastest pulse sequences in Open MRI
- Fastest reconstruction, up to 850 images/sec at 2562-FFs
- 65% faster post-processing powered by Linux OS
Magnet Type | Permanent |
Weight | 19200 kg |
Clinical Use | Whole Body |
Magnetic Field Strength | 0.35 T |
