GE HealthCare - Transport Pro
by GE HealthCare
High-acuity transport monitoring
The Transport Pro monitor helps simplify and speed the transfer process and, when used with the CARESCAPE Patient Data Module, helps eliminate data gaps and ECG template resets that typically occur while moving from bedside to transport monitor. Its Li-Ion battery technology provides up to a four-hour run time and can be exchanged while in use for continuous monitoring without data loss.      The Transport Pro has a multi-colored alarm light; alarm volume can be lowered to allow for quieter transports so neonates or sleeping patients are not disturbed.
FORUMSView All (3)
-DCRUMP2016
Mon Jul 31 2023
GE HealthCare Transport Pro Tram To PDM module issues.
Hello
I have a GE Transport Pro vital signs monitor that was setup being used with a tram 451 n module and works great. But it also has an ePort for the Ge PDM module cradle to attach to it. So I have attached a known good PDM cradle that was on a working system and installed the PDM module and it will not recognize the PDM module it gives error on the screen Service Acquisition Device in red no communications. Does anyone have any thoughts about what is wrong? I'd appreciate any and all help with this issue. Oh yea the software revision is 2.1C main and boot.
Thanks David
-me_samm
Mon Apr 03 2023
Error Code 490C
What does error code 490C refer to? Is it a battery error?Reply
-mschmitz
Mon Aug 10 2015
trim knob
Rugged: built to withstand the rigors of frequent location changes, Transport Pro has been drop-tested for reliability      Versatile: the optional bed rail hook and pole mount allow the monitor to be visible and secure at all times
