B. Braun - McGaw Horizon NXT
Equipped with two automatic multiple delivery rate modes
The Horizon NXT is intended for use with B. Braun McGaw Horizon I.V. sets to regulate the flow of primary and secondary fluids when positive pressure is required. The infusion system is capable of delivering fluid from a negative head height (when the I.V. fluid container is lower than the pump), and provides clinically accepted volumetric accuracy for all standard I.V. fluids, including blood, lipids and TPN.
FORUMSView All (3)
0Replies7 years ago | Horizon NXT over Delivering For example I set the rate at 500 ML, and the volume would be 510/520 when it's done. is it the solenoid or Pressure Transducer?? or should I just replace the Half Door/Bezel Assembly??? Reply |
2Replies9 years ago | Container is Empty Does anyone know how to solve a container is empty alarm? I know this alarm to be false every time the pump gives it but I havent been successful in solving the issue. Reply |
0Replies9 years ago | "Solution" Error I have a pump that is giving the "Solution" error. When I check the error log, it states that the container is empty which I know to be false. Any suggestions? Reply |
- Epidural Administration - can be used for epidural administration of anesthetic and analgesic drugs
- Blood Infusion - can be used for infusion of blood and blood products
Volume to be Infused | 0.1 to 999.9 ml |
Height | 4.5 in |
Length | 8.75 in |
Flow Rate Range | 0.1 to 999.9 ml/h |
KVO Rate | 3 ml/h |
Weight | 11.9 lbs |
Infusion Pump Type | General-Purpose |
Width | 12 in |
