Pulse Oximeter
The Nellcor N-595 Pulse Oximeter is a portable innovation from Nellcor, one of the leaders in pulse oximetry monitoring. The N-595 employs highly effective motion resistance monitoring to give the practitioner an accurate reading at all times. This monitor is intuitive, easy to use and extremely reliable. The N-595 can be used in any department and monitors neonates thru adults (with the accurate sensor for the patient.) Beep tone alarms alert the hospital staff to changes in SPO2 saturation, and the volume can be adjusted as necessary. Pre-programmed alarm limits for neonates and adults can be easily selected.
- Simple, intuitive operation and easy-to-see display.
- Ideal for any clinical environment—monitors neonates through adults.
- Convenient selection of adult or neonate alarm limits, and user-configurable power-on settings.
- Works with the Oxinet III Central Station and Paging System to provide an easy-to-use, cost-effective monitoring solution for the General Care Floor.
- Compatible with Nellcor's Score Analysis Software for overnight oximetry studies.
- User-selectable fast-averaging mode (2-3 seconds) to more precisely track rapidly changing saturations.
- On-screen viewing of 48 hours of SpO 2 and pulse rate trends taken at 4-second intervals; printing capability.
- Variable pitch beep tone enables clinicians to hear changes in SpO 2 .
- Interfaces with certain multiparameter monitors; real-time patient information and true physiologic waveforms are displayed on host system.
| Height | 3.3 in |
| Length | 6.8 in |
| Weight | 5.7 lbs |
| Width | 10.4 in |
- 3.3 in. x 10.4 in. x 6.8 in. (8.4 cm x 26.4 cm x 17.3 cm)
- Weight: 5.8 lbs ( 2.6 kg)
- Operating Temperature: 5 ºC to 40 ºC (41 ºF to 104 ºF)
- Operating Altitude: -390 m to 3,012 m (-1,254 ft. to 9,882 ft.)
- Operating Atmospheric Pressure: 70 kPa to 106 kPa (31.3 in. Hg to 20.6 in. Hg)
- Operating Relative Humidity: 15% to 95% non-condensing to be compliant with IEC 60601-1, sub-clause 44.5
- Transportation and Storage Temperature: -20 ºC to 60 ºC (-4 ºF to 140 ºF)
- Trasportation and Storage Altitude: -390 m to 5,574 m (-1,254 ft. to 18,288 ft.)
- Transpor and Storage Atmosphereic Pressure: 50 kPa to 106 kPa (31.3 in. Hg to 14.7 in. Hg)
- Transport and Storage Relative Humidity: 15% to 95% non-condensing
