Stryker - 1061 Gynnie
by Stryker
The Stryker Gynnie Gurney is the solution for labor and delivery needs in the hopital. Stryker combines their time-tested engineering with innovatitions for the OB department. This gurney is ideal for pelvic exams and general use, and can be used in any department with its multi-functional design. An adjustable footrest design allows the practioner to position the patient by one-handed operation. the 4" thick mattress provides support and comfort for extended time on the stretcher. Pop-up push handles and a retractable fifth wheel allow the gurney to be maneuvered easily around corners and down hallways for transport.
3RepliesFri Oct 09 2020 | SHOCK PARTS I need to buy shock parts for my stretcher can someone give me a part number or point me in the direction where i can find one??? Reply |
1ReplyTue Jan 28 2020 | Wheels I need replacement wheels for Gynnie, or maybe just the black rubber covers if availibleReply |
2RepliesTue Jan 24 2017 | Shipping Weight Stryker 1061 Gynnie Stretcher I can't find specifications that show the shipping weight. I had 400 lb. A freight carrier is trying to say it was 1,053 lb. We know that's way off. Thank you. Reply |
[list][*] Dual cylinder pneumatic backrest [*] Dual side-mounted foot control hydraulics [*] Retractable fifth-wheel steering [*] Four-wheel, steel ring brakes [*] Pop-up Push Handles [*] Roller Bumpers [*] Three IV Receptacles [*] One-Handed Foot Section Release Lever [*] Permanently-attached folding foot section [*] Permanently-attached foot supports [*] Break-away pelvic section [/list]
| Height | 36 in High, Low-22.5 |
| Length | 81.5 in |
| Patient Weight Capacity | 500 lbs |
| Width | 31.5 in with siderails up |
Patient Surface: 26" wide
