GE HealthCare - Discovery PET/CT 690
by GE HealthCare
Take molecular imaging beyond the clinical practice with the GE Discovery PET/CT 690 – designed to help users forge the future of PET/CT.
Investigate with a comprehensive set of research technologies. Advance users protocol flexibility beyond the standards. Unleash the power of accurate reconstruction and reliable results – without clinical compromise. Featuring a unique detector configuration designed for sensitivity and efficiency, the Discovery PET/CT 690 gives users the speed, power and flexibility to forge new frontiers in clinical techniques, drug discovery and motion management.
0RepliesFri Jan 06 2012 | Can you bin the motion CT iamges? Can your software package bin the datasets? Reply |
| Crystal Thickness | 25 mm |
| Weight | 9340 lbs |
| Maximum Scan Range | 200 cm |
| Scintillator Type | Lutetium Oxyorthosilicate (LSO) |
| Scan FOV | 9.6 cm |
| Axial slick thickness range [mm] | .6-5.0 |
| Axial Field-of-View (AFOV) | 15.7 cm |
| Gantry (Max. Clearance) | 70 cm |
| Patient Weight Capacity | 500 lbs |
Minimum room size (length x width x height) 13'4" x 25'6"
