Philips - Gemini TF Big Bore
PET/CT Scanner
When it comes to streamlining the processes involved in diagnosis, staging, therapy planning, and follow-up in oncology care, the Philips GEMINI TF Big Bore system lets users do more for patients, more efficiently. GEMINI TF Big Bore is the world’s first PET/CT system, combining 3rd generation Time-of-Flight PET performance with the market leading Brilliance CT Big Bore simulator.
SERVICE COMPANIESView All PET/CT Scanner Companies
- The GEMINI TF Big Bore PET/CT scanner facilitates the use of PET in radiotherapy planning by offering integrated solutions to streamline tumor detection, staging, simulation and monitoring therapy response.
- Seamlessly integrate information about tumor metabolic activity, as well as structure, into the radiation therapy planning process in ways not possible until now.
- Improve treatment accuracy with the same wide bore opening for both PET and CT, which allows patients to be positioned in the same manner for both simulation and therapy.
- 4D Time-of-Flight respiratory motion management.
- Leverage the significant workflow and clinical advantages of Brilliance CT Big Bore, such as Tumor LOC.
- Interact seamlessly with the Philips Pinnacle³ radiation treatment planning system.
- Allow automatic segmentation and monitoring of tumor progression before, during, and after therapy with Tumor Tracking application.
Crystal Thickness | 22 mm |
Slices | 16 |
Weight | 8500 lbs |
Maximum Scan Range | 190 cm |
Scintillator Type | LYSO |
Scan FOV | 60 cm |
Axial slick thickness range [mm] | .75-12 |
Axial Field-of-View (AFOV) | 18 cm |
Gantry (Max. Clearance) | 85 cm |
- Minimum room size (length x width x height) 23-9 x 13-6 x 8 in
