Siemens - Biograph TruePoint
by Siemens
Siemens Biograph is a flexible, high-powered medical imaging platform.
Siemens Biograph offers an wide range of performance options to enhance image resolution and quality, improve patient satisfaction as well as throughput. Customize the Biograph solution to meets users' specific needs by selecting from various multislice CT configurations, high or standard resolution options, and clinical configuration options.
-WBelinato
11 years ago
Inherent Filtration and bowtie filter
Dear all,
I need information beam Biobraph true point. inherent filtration and bowtie filter collimation   can anyone help me?   Thanks,   Walmir
SERVICE COMPANIESView All PET/CT Scanner Companies
  • Uniform resolution throughout the field of view with HD•PET
  • Largest PET field of view in the industry, increasing count rate performance by >70%
  • Exceptional lesion detectability with the best NEMA spatial resolution in the industry
Crystal Thickness20 mm
Slices6,16,40,64 (optional)
Weight8750 lbs
Maximum Scan Range190 cm
Scintillator TypeLutetium Oxyorthosilicate (LSO)
Scan FOV15 to 70 cm
Axial slick thickness range [mm].5-10
Axial Field-of-View (AFOV)16.2 cm
Gantry (Max. Clearance) 70 cm
Patient Weight Capacity450 lbs
Minimum room size (length x width x height) -16.5 x 26 x 8 ft
