Getinge - Shampaine 5100B
by Getinge
The 5100B major surgical tables provide flexible articulation for complete patient positioning. Through the use of Electroluminescent (EL) technology, the 5100 series tables are the only tables available with “Full-Function Key Illumination”. These tables have a longitudinal slide feature for full length image amplification. Each of the five table sections, including the 15'' leg extension, come standard with a built-in x-ray cassette tunnel. These tables are capable of returning to the horizontal position (true level) through the convenience of one button activation. The 5100B is battery-powered. The table may be operated with or without the power cord connected. Mains power is only required to recharge the battery. The battery recharge system will restore completely discharged batteries to 80% of full charge within eight hours (8) and bring the table to a full charge within twelve (12) hours of continuous charging.
0Replies7 years ago | battery replacement diagram or access to replace batteryReply |
0Replies8 years ago | Remote hand control The head,foot,table up/down works. Trend head/trend foot, left tilt,left slide, left flex,start/stop, lock/unlock and level works. Right flex,right tilt and right slide not working. I ring the 5 conductors end to end and it is okay. Please help. Reply |
2Replies9 years ago | Error code 1 Hello i am loking for an answer, i have a surgery table shampaine 5100 and it not work, just give me a error code 1 on the display
what it means?
i hope that someone can help me
thanks Reply |
[list] [*] Low Voltage Control Box [*] Pump/Motor Assembly [*] Batteries [*] Hydraulic Manifold Block [*] Solenoid Valves [*] AC Power Input Module [*] Manual Foot Pump [/list]
Height | 28 in to 43 |
Length | 72.5 in |
Width | 19 in |
