Mindray - A5
by Mindray
Clear / Explicit / Precise
The A5's user interface and ergonomic design simplifies workflow. The 15” touch screen enables clinicians to easily select ventilation settings, so less time is spent maneuvering and more time is devoted to patient care.                        The A5 provides a range of advanced ventilation modes enabling effective care across the range of patient acuity types. Integrated spirometry offers additional information and enhances careful decision making.                        The auxiliary Oxygen/Air flow meters deliver blended gas through the nasal cannula, allowing the clinician to maintain their preferred clinical practice without increased risk of surgical fire.                        The A5 conforms to the IHE (Integrating the Healthcare Enterprise) Patient Care Domain (PCD) profile. A5 is capable of outputting data in industry standard HL7 protocol. HL7 with the IHE PCD profile is recognized by anesthesia information and electronic medical records (EMR) systems as the demonstrated industry standard for unambiguous interoperability.                        The A5's ample work surface, comfortable foot rest, central brake and integrated cable sweeps enhance device mobility.
FORUMSView All (10)
-SME
Invalid Date
Mindray A5 Anesthesua mother board
we are seeking for Mindray A3 A5 A7 A-3 A-5 A-7 respiratory anesthesia machine A series monitoring board circuit board, any one who can provide me , kindly contact me
to my email : yshamali@hotmail.com
Equipment: Mindray A5 anesthesia mother board
-Psalmson
Invalid Date
Sonoscape A5 not showing transducer wave on screen
Sonoscape A5 not showing transducer wave on screen even though the machine is recognising that the probe is connected. I tried off and oning the machine and changing port but not working. When you on the machine it allows you to select probe and examination type after which you wont see d transducer wave on screen nor does it show any imageReply
-Zeko613
Invalid Date
Mindray a5
Hi everyone Can you help me I need Software Upgrade for mindray A5 This is name software *Mindray Anesthesia Machine and Ventilator Software Upgrade Tool* If anyone can sent to me this is my email zakaria613613@gmail.com Thank you everyone Reply
[list]            [*] Volume Control Ventilation (VCV)            [*] Pressure Control Ventilation (PCV) with volume guarantee            [*] Pressure Support Ventilation (PS)            [*] Synchronized Intermittent Mandatory Ventilation in volume and pressure modes (SIMV-VC and SIMV-PC)            [*] Automatic compliance compensation and fresh gas compensation maintain accurate tidal volumes            [*] The warmed Breathing System (35º C) virtually eliminates internal condensation            [*] The built in caster guard design clears away cables and hoses            [*] The economical single container absorber reduces compressible dead space volume and accepts non-proprietary prepackaged and loose fill absorbent            [*] Integrated backup control touchpad            [*] Deck lighting with adjustable brightness control            [*] Two hour battery backup            [/list]
Height55.1 in
GasesAir, Nitrous Oxide, Oxygen
Length 31.7 in
Vaporizers (Max)Two
Weight353 lbs
Inspiratory Flow (max)30 L/min
Vaporizer TypeElectronic control
Vent ModesVolume Control Ventilation (VCV) and Pressure Control Ventilation (PCV), Pressure Support, Manual/spontaneous
Width41.3 in
FDA AlertsView All
Class 1 Recall: Mindray A3 and A5 Anesthesia Delivery System
The affected anesthesia delivery systems may have a gasket leak which could cause an interruption of or inadequate patient anesthesia and ventilation, temporary or permanent patient injury, or death.
