Netech - Delta 1500
by Netech
The DELTA 1500 AED Analyzer is a precision diagnostic instrument engineered to verify the performance and safety of Automated External Defibrillators (AEDs). Designed for biomedical engineers and medical equipment technicians, it allows for quick and accurate testing of AED arrhythmia recognition, energy charge/discharge, and delivered energy output through a simulated human thorax load.
The DELTA 1500 simulates normal sinus rhythm (NSR), ventricular fibrillation (VFIB), and ventricular tachycardia (VTACH) waveforms, all selectable via soft-touch keys. Upon AED discharge, the analyzer measures and displays delivered energy in joules on a large, easy-to-read LCD screen. An automatic test mode seamlessly transitions from VFIB to NSR following energy discharge—reducing AED battery use and simplifying the testing process.
Compact, durable, and reliable, the DELTA 1500 AED Analyzer is the ideal testing tool for AEDs deployed in ambulances, hospitals, police departments, schools, sports facilities, aircraft, and public areas. When paired with the 610-Paddle Adapter, it can also test AEDs with reusable paddles.
Each unit includes insulated banana jacks and a protective soft carrying case, making the DELTA 1500 a must-have instrument for any biomedical engineer performing AED inspection, calibration, or preventive maintenance. (Generated by AI)
[list] [*] Fast, Accurate. Portable [*] Easy to use [*] Dependable [*] Large LCD Display [*] Battery Operation [/list]
| Analyzer/Simulator Type | Defibrillator |
Display:4 Digit 0.5 inch LCD Internal Test Load:50 Ohms +/- 1%
