Netech - Digiflo 1000
by Netech
The DigiFlo Digital Flow Meter is a microcontroller-based mass flow meter engineered for precise and reliable measurement of medical and laboratory gases, including Air, Nitrogen (N‚), Oxygen (O‚), and Carbon Dioxide (CO‚). Designed for high accuracy and stability, the DigiFlo provides true gas flow readings independent of temperature and pressure variations, ensuring consistent performance in clinical, research, and industrial environments.
Flow rates are displayed directly in Standard Cubic Centimeters per Minute (SCCM) for easy and accurate data interpretation. The DigiFlo utilizes an advanced micro-mass flow sensor that operates on the principle of heat transfercaused by mass airflow across the sensing element, delivering rapid and precise measurement results.
Ideal for biomedical engineers, respiratory equipment testing, and gas calibration laboratories, the DigiFlo Digital Gas Flow Meter combines accuracy, ease of use, and durability in one compact, portable instrument. (Generated by AI)
0RepliesThu Feb 27 2014 | Unstability When check the fñow from an equipment the DigiFlo 1000 the readings are not constants, present fulctuation in the data. What maybe cause the problem? Reply |
[list] [*] Fast, Accurate & Portable [*] Reliable: Direct reading. No temperature and pressure correction needed. [*] Convenient: No glass columns, No liquids, No bubbles, and No look-up tables. [*] Easy to use: Menu driven and user friendly [/list]
| Analyzer/Simulator Type | Flow Meter |
Display:Two line 16 charactor LCD Max Pressure:20 Pounds Per Square Inch (PSI) Accuracy: +/- 2% of reading, + 1 Digit Flow Range (Volume) 0.1 to 500 Standard Cubic Centimeters Per Minute (SCCM) Auto-ranging (Air and N2). Other gases vary
