Netech - UniMano 2000
by Netech
Pressure / Vacuum / Temperature Meter
UniMano 2000, Pressure / Vacuum / Temperature Meter is a universal manometer designed to measure both positive and negative pressures of the pneumatic or hydraulic systems. It is designed for the precise measurement of Pressure, Vacuum and Temperature.The additional feature to measure temperature in Centigrade or Farenheit makes it a versatile test instrument.        UniMano 2000 is available in many standard pressure ranges with either YSI 700 series, RTD K or J types of temperature measurement. UniMano, Pressure / Vacuum / Temperature Meter is available in 3 different models with maximum pressure ranges of 30 PSI, 60 PSI and 100 PSI with temperature capability with YSI 700 K/J type probes.
[list]    [*] Versatile: Three in one - Pressure, Vacuum and Temperature    [*] Pressure Ranges: Three Models to choose from 30 PSI, 60 PSI and 100 PSI.    [*] Enhanced Functions: Peak hold, Leak detection, Auto Zero.    [*] Temperature: YSI 700 or K/J Types    [*] LCD Display: Easy to read 16 2 LCD display    [*] Battery Powered: One 9 Volt alkaline battery    [*] Compact: Compact ABS plastic case.    [/list]
Analyzer/Simulator TypePressure Meter
