Kendall - 5325 SCD
by Kendall
The Kendall 5325 SCD ( Sequential Compression Device) is designed to limit the development of Deep Vein Thrombosis (DVT) and Peripheral Edema in immobile patients. When a patient is immobile for long periods of time, as in recuperation from an injury, blood tends to pool in the calf area of the lower leg. To combat this tendency, clinicians use the Sequential Compression Device. This consists of an air pump connected to a disposable sleeve by a series of air tubes. The sleeve is placed around the patient’s leg. Air is then forced into different parts of the sleeve in sequence, creating pressure around the calves and improving venous return.
The Kendall Model 5325 uses tubing KE5378A. The tubing can be used for two extremities at once, or one side can be capped for single extremity use. One disposable sleeve is required for each extremity being compressed, and the same sleeves can be wrapped around either a leg or arm, although most clinicians use these machines only for lower extremities.
1Reply11 years ago | Kendall 5325 SCD. I am looking for a sevice manual for Kendall 5325 SCD. I have a unit that constantly gives SL error message. CHecked the pump and solenpoids and tubing. All seem to work. Error message occurs when inflating the thigh section. Reply |
1Reply12 years ago | 5325 SCD Does anyone have a service Manual? Unit shows error 5L after start-up verification completes. It completes all self test, ankle, calf and thigh then errors. it has a good hose assm and 2 good cuffs and no leaks.Reply |
Height | 6.5 in |
Length | 13 in |
Weight | 14.3 lbs |
Width | 8.6 in |
Power Requirements:115 VAC, 115 VA, 60 Hz
Compression Type: Sequential, Gradient Pressure
Compression Cycle: 11 seconds compression, 60 seconds decompression
Set Pressure: 45 mmHg
Sleeve Cooling:Yes
Cycle Monitor: Yes
Alarms:Low Pressure, High Pressure, Internal Electronics Malfunction
