Kendall - 6325 SCD
Response Compression SystemThe Kendall 6325 Response Compression System is designed to apply sequential compression to the lower limbs to help prevent deep vein thrombosis in patients at risk. The model 6325R Controller has been upgraded from an SCD Sequel Compression System Model 6325 Controller. The System consists of the Model 6325R Controller, the Tubing Set (provided with the Controller), and the use of single-patient use SCD Sleeves (purchased separately from this Controller). The Sleeves compress the limbs to enhance venous blood movement. After the compression, the Controller measures the time it takes for the legs to refill with blood and waits that period of time before the next compression in initiated.
0Replies11 years ago | Time How can shorten the time between cycle, it inflate like very 60 sec, is ther way to shorten the time ?
Thanks Reply |
2Replies12 years ago | compressions sleeves for this device Hello. I am interested in your Kendall 6325. I have some sleeves, which are Kendall 5330 'soft sleeves' with a four-hole snap connector. I know that some units are three hole and want to confirm how many holes / tubes there are on the connector for each leg sleeve on the 6325 unit. Thanks Reply |
[list] [*] Reduces the effects of deep vein thrombosis (DVT) [*] Reduces post surgery pain and swelling [*] Stimulates arterial blood flow [/list]
Weight | 8.9 lbs |
Compression Type: Sequential, Gradient Pressure Compression Cycle: 11 Seconds Compression, 60 Seconds Decompression Set Pressure: 45 mmHg Bed Hook: Yes Power Cord Storage: Yes Audio/Visual Alarms: Low Pressure, High Pressure, Internal Malfunction Sleeve Cooling Function: Yes Cycle Monitor: Yes Power Cord: Hospital Grade Plug Controller Height: 6 inches Controller Width: 10.75 inches Controller Depth: 4.5 inches Power Requirements: 115 VAC, 86 VA, 60 Hz
