Kendall - Response 7325
by Kendall
The Kendall 7325 Response SCD is a clinically proven, non-invasive method of prophylaxis to reduce the incidence of deep vein thrombosis (DVT). For use on patients with high risk conditions such as obesity, advanced age, malignancy, or prior thromboembolism. Pneumatic controller provides intermittent of pulses of compressed air which sequentially inflate the multiple chambers of the sleeve beginning at the ankle and moving up the leg. Results in a wave-like milking action which empties the veins and results in greatly increased peak blood flow velocity. Disposable sleeves available in knee and thigh lengths. Thigh-length sleeve available in sterile packaging for use on the draped leg during major hip surgery. Equipped with features that assure maximum control, safety and patient comfort. Various purchase programs available. The SCD RESPONSE Compression System can detect each patient's individual vascular refill rate to deliver the most reliable, efficient, customized compression therapy on the market.
2RepliesFri Jun 27 2014 | need service manual need download of service/operation manual Reply |
0RepliesMon Dec 23 2013 | Pump not cutting on Found a connection that is loose -connects CPU PC board to power supply board with a flex cable- not sure if it is the flex cable (male connector) or the power supply ( female connector). Was wondering if it was possible to replace the connectors or if I am going to have to replace both the ribbon Cale and the power supply board. Also need info on parts available and where. Reply |
1ReplyWed May 09 2012 | No problem Do you purchase used equipment in Spokane wa.? Reply |
[list] [*] For use on patients with high risk conditions such as obesity, advanced age, malignancy or prior thromboembolism. [*] Pneumatic controller provides intermittent of pulses of compressed air which sequentially inflate the multiple chambers of the sleeve beginning at the ankle and moving up the leg. Results in a wave-like milking action which empties the veins and results in greatly increased peak blood flow velocity. [*] Disposable sleeves available in knee and thigh lengths. [*] Thigh-length sleeve available in sterile packaging for use on the draped leg during major hip surgery. [*] Equipped with features that assure maximum control, safety and patient comfort. [*] Can detect each patient’s individual vascular refill rate to deliver the most reliable, efficient, customized compression therapy on the market. [/list]
