MAQUET - ORTHOSTAR II 1425
ORTHOSTAR II is a special operating table for orthopaedic surgery and traumatology.With its excellent properties for extension treatment in traumatology, the mobile operating table ORTHOSTAR II is a proven unit for all procedures of osteosynthesis. Furthermore, the functional conception of the ORTHOSTAR II provides comprehensive possibilities of use in orthopaedics and spinal surgery. For shoulder operations, the ORTHOSTAR II includes a back plate with electro hydraulic adjustment. This integrated interface allows adapting special accessories packages for demanding patient positioning during surgical interventions on the spinal column. Together with the specially developed accessory units for the classical area of traumatology, the ORTHOSTAR II is a versatile, special purpose operating table which is interesting in terms of cost, too.
FORUMSView All (6)
0Replies5 years ago | Service Manual Maquet ORTHOSTAR So please someone could help me with the service manual because I have a problem. If the table is connected to 220 outlet it works but dissconected it doesn't work. I changed the old batteries for new ones and I replaced the voltage comparator but still with the same problem. Any help is useful. Thanks a lotReply |
1Reply5 years ago | Service Manual I need the service manual of this maquet table. Reply |
1Reply6 years ago | Service manual I need service manual for maquet orthostar..please let me know if any one have this manual. Oil leakage from tilt cylinder sealer Reply |
Height & load capacity With a minimum height of 810mm and a maximum height of 1175mm ORTHOSTAR II is perfectly adapted to all kinds of surgery in orthopaedics and traumatology. With a maximum load capacity of 225kg ORTHOSTAR II is well prepared to handle even heavy patients. Shoulder plate The shoulder plate is electrohydraulically adjustable and permits easy handling. Extension treatment Integrated traction bars allow for excellent extension treatment in traumatology. SFC padding The SFC padding (80 mm) with multi-layer design offers patients significantly greater comfort and supports decubitus prevention.
Height | 810 mm to 1175 mm. |
Patient Weight Capacity | 225 kg |
