SonoScape - A6
by SonoScape
The A6 has excellent B and M-mode imaging, solid DICOM connectivity that connects into PACs and EMR system along with a portable form.
1Reply2 years ago | interior power supply Ultrasound repair companies do not seem to be able to get parts for this machine. Any suggestions for getting the power supply unit - either used or new? Equipment: Sonoscape Ultrasound A6V Reply |
0Replies4 years ago | A6 system update Hi there, Can someone help with how to update the system. The screen is showing a message to ipfate and since thst day the machine is not if use. I tried to call several company but it did not work out. Please help it has been used to provide care to pregnant women in africa at low cost.Reply |
2Replies4 years ago | Sonoscape A6 not displaying the exam type under each probe Hello. Our Sonoscape A6 recognizes the 2 probes connected, but does not display the exam types under each of the probes. Please how do I solve this? Can resetting the system help, how do I reset the system or reinstall the software? Does anyone have the software, also does anyone have a service manual for this machine?Reply |
| Weight | 13 lbs |
| Clinical Applications | General |
| Portable | 1 |
| Doppler Modes | B-Mode M-Mode B-Color Dual screen Quad screen |
| Image Display | 12 in LCD screen |
| Imaging Mode | B/M |
Probes that work with this system: 50mm Convex probe C351 [ 2-6 MHz ] 40mm Convex probe C543 [ 3-8 MHz ] 15mm Convex Cardiology probe C312 [ 2-5 MHz ] 13mm Micro-convex probe C612 [ 4-9 MHz ] 46mm Linear probe L745 [ 5-11 MHz ] 60mm Linear probe R10 [ 5-1 MHz ] 13mm Endovaginal probe 6V4 [ 4-9 MHz ] 10.3mm Endovaginal probe EC2 [ 4-9 MHz ] 10mm Biplane Transrectal BCL10-5 [ 4-9 MHz ]
