SonoScape - S8
S8 is a high-end color Doppler HCU (Hand-Carried Ultrasound) from SonoScape. This system expresses the words of an ever-higher standard of Echo HCU.
Although S8 is a HCU system, its performance is equal to high-end cart-based echo ultrasound systems. This flagship HCU is incorporated with high configuration to meet the strictest requirements from cardiologist, such as adult TEE, pediatric TEE, high frequency phased array, 15 MHz linear transducer, 512 super high density transducers, 4D imaging function, and so on.
FORUMSView All (8)
3Replies4 years ago | Sonoscape S8/S8Exp service manual needed Probes are identified but there is no signal from them. Could anybody help? Reply |
1Reply7 years ago | Backup data how to copy data from internal HDD to a USB?Reply |
0Replies8 years ago | Menu button not working Has anyone had a problem with the Menu button not working? My sonoscape S8 has always worked great but suddenly when I push the Menu button, nothing happens. Makes it impossible to save or retrieve studies. Reply |
- HCU design with two transducer sockets
- Convertible trolley design
- 15″LCD monitor with super large imaging area
- Full cardiovascular transducers: TEE, Pediatric TEE, Phased array, High frequency phased array, High-frequency linear, etc.
- High density transducers with frequency ranges from 1.9 to 15MHz
- Integrated with state-of-the-art technologies, like Μ-scan technology, IMT, multiple-beam processing, automatic flow volume analysis, 4D imaging technology, etc.
- Comprehensive cardiovascular analysis kits: TDI, Steer M, Color M; CW, HPRF, Panoramic image, etc.
- Full patient database solutions: DVD RW,DICOM3.0, AVI/JPG, USB2.0, HDD, PDF report, etc.
- Built-in high capacity Li-ion battery
Weight | 19 lbs |
Clinical Applications | Colorectal |
Imaging Capabilities | 3D/4D |
Portable | 1 |
Doppler Modes | B-Mode M-Mode B-Color Color Doppler Power Doppler Spectral PW Doppler Steerable CW Doppler 4D Volume 3D |
Image Display | 15 in LCD monitor |
Imaging Mode | B/M |
Probes that work with this system: Convex probe C344 [ 2 - 5 MHz ] Convex probe C362 [ 2 - 5 MHz ] Convex probe C542 [ 4 - 7 MHz ] Microconvex probe C311 [ 2 - 4 MHz ] Microconvex probe C611 [ 4 - 10 MHz ] Cardiac Sector probe 2P1 [ 2 - 4 MHz ] Cardiac Sector probe 5P1 [ 4 - 11 MHz ] Linear T probe L743 [ 5 - 15 MHz ] Linear Rectal probe L741V [ 5 - 10 MHz ] Multi-plane TEE probe MPTEE [ 4 - 7 MHz ]
