GE HealthCare - Voluson e
by GE HealthCare
 The Voluson e is a unique compact ultrasound system that is designed for user's practice.
Voluson e brings unprecedented 2D image quality to an even wider range of clinicians. Its light, portable package provides flexibility to serve patients in any care setting.
FORUMSView All (7)
-dacruz
Sat Dec 06 2025
Fractured looking image regardless which probe or port
I have a fractured looking image on both an old and a new probe. The pattern in the fractured image is the same for both the old and brand new probes. The fractured image persists regardless of which probe port is used. On two of the many boot ups, I got an error not present in the service manual, and the probe fails to load at all. "Invalid access to CoeffRAM MMU detected NATHAN LUT error" The probe in quest is an RAB 6-D. Anyone have any ideas where the issue is? I'm especially curious if you've ever run into this problem before, which likely isn't specific to this model of ultrasound system.
Equipment: Voluson e6 EC200 (BT13)
-Shamim66
Thu Jan 23 2025
PW / M mode in dual screen format
I see that PW or M mode can't be used in dual screen format in voluson e8. But I used this feature in dual mode in logiq series, even in earlier version like p5.
Is there any way to activate this function in voluson e8??
Is it possible to use PW in dual or quad screen format??
Thanks in advance.
Equipment: GE HealthCare - Voluson e8
-Cris_XP10
Tue Feb 05 2019
Problems while recording videos
Hello Dears, Sometimes the machine stops working and I need to restart it so that I can do exams. It just happen when I try to record a video into a DVD midia. ThanksReply
  • Light, Portable Package
  • Voluson e provides flexibility to serve patients in any care setting
  • Ergonomic design addresses every aspect of user comfort
  • Best of all, users get stunning image clarity that improves diagnostic confidence
  • Excellent 2D image quality
  • Speckle Reduction Imaging (SRI II) for improved contrast resolution and border detection
  • CrossXBeam Imaging (CRI) for enhanced tissue and border differentiation
Height2.3 in
Length 12.4 in
Weight11 lbs
Clinical ApplicationsGeneral
Imaging Capabilities2D/3D/4D
Portable1
Color-flow Mapping1
Doppler Modes3-D, Color, Pulsed wave (PW)
Width14.2 in
