Lancer - 1400 TI/TIDP
by Lancer
The 1400 TI / 1400 TI DP high performance Industrial Washers provide effective mechanical, thermal and chemical cleaning. The 1400 TI / 1400 TI DP washer is designed to meet the growing demands of the biotechnology, agritech, petrochem, pharmaceutical, QA/QC laboratories and other industries. It's rugged design and superior construction materials (chamber, door and valves of 316 L stainless steel) help to withstand the aggressive products found in industrial applications. Advanced options including traceability of cycles, validation of cycles, chart recording and a conductivity meter for the more rigorous requirements of industrial applications are available.The 1400 TI / 1400 TI DP models include chamber drying and have a single door(TI) and double door(TI DP) variation for pass through applications.
[list] [*] Rugged design for industrial applications [*] Main recycling pump constructed of stainless steel to withstand aggressive chemicals [*] Chamber and door constructed of 316 L stainless steel [*] Advanced options: traceability, validation, conductivity meter and additional dosing pumps [*] Double door configurations for pass through applications All Lancer washers feature these key benefits: [*] Fast cycles and outstanding results from powerful wash action and design [*] Easy to use microprocessor controls with self-diagnostic software and alarms [*] Flexibility of multi-level injection washing and interchangeable racks [*] All sizes and types of glassware cleaned with chamber configuration choices [*] Ergonomic and safe loading of racks on load bearing telescopic runners [*] Choice of preset and user-customized (PIN code protected) programs [*] Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps [*] Robust high grade 304 L and 316L stainless steel construction (varies by model) [*] IQ/OQ protocol and validation options available [*] Cost effective – low life cycle costs and efficient operation uses less resources and inventory [*] Eco-friendly low energy, chemicals and water usage [/list]
