Edan - SE-3
Smart ECG SE-3 series are high-quality and affordable three-channel ECG units.Smart ECG SE-3 series are high-quality and affordable three-channel ECG units. Compact and light design makes it portable for any work situation.
FORUMSView All (7)
0Replies7 years ago | Edan - SE-3 how to enter to "advanced setup"? i need password. i need clean internal memoryReply |
3Replies9 years ago | need service manual the device doesn't power on. i found a broken mosfet on the battery pack. i replaced it and it works now (on another Edan SE-3). on the power supply section misses the "Main" 5VDC voltage but if i try to send it externally the ecg try to power on for some second but then it shut down. i need the service manual to find which ICs send the "enable" signal throgh 74hc08 to ACT4070 to complete the starting stage. Thank you very much Reply |
0Replies9 years ago | mike s. How often does an Edan SE-3 ECG mon need the battery replaced? Reply |
- Foldable LCD screen with waveform display and parameters configurable
- High resolution thermal printer
- Built-in rechargeable lithium battery, AC/DC power supply
- Well designed membrane keyboard
- Muti-languages selectable
- Data transmission to PC via RS232/Ethernet port
- USB Interface for patient data transportation
- Compatible with external printer for 12 leads simultaneous printing
- Complete digital filter, avoiding baseline drift, AC, EMG interference
- Automatic baseline adjustment to optimize printing position
- Copy mode for additional copies of the latest auto-tested ECG
- 3/6/12 leads display simultaneous
- Lead-Off detection and alert
- Selectable report options : auto, manual, rhythm and HRV analysis
- Interpretation tested with authoritative CSE database (option)
EKG/ECG Type | Rest |
