STERIS - AMSCO 3080
The Amsco 3080 features a radiolucent top and can be adjusted to Trendelenburg, back, side, foot and flex positions. It comes standard with a remote control for easy patient positioning.
FORUMSView All (17)
1Reply3 years ago | Steris 3080 will not auto level This just happened today, I can tilt and perform all adjustment but the table will not auto level. I tried a different hand control ( pendant ) from another working bed and the same result. Thanks DwightReply |
0Replies3 years ago | hydraulic leak Hi all, I hope that you can help me on an Amsco 3080RL surgical table. This table is leaking oil and the only thing that I found on the table was a piece of tubing (that goes from the foot pump to the electrical pump) has split and the table is low on oil. My question is: what type of oil do I use and is that possibly where it was leaking? Thank you, MikeReply |
5Replies4 years ago | Purpose of the Superthane tubing that connects the pumps What is the use of this tubing? It connects the manual pedal pump to the electric hydraulic pumpReply |
- Remote control
- C-ARM Compatible
- Return to level and special positioning models available
- Up to 500 lb capacity
Height | 27 in to 44 |
Tredelenburg | 25 degrees |
Lateral Tilt | 18 degrees |
