Zoll - Alsius CoolGuard 3000
by Zoll
The CoolGard 3000 system provides precise and rapid control of your patient's core temperature for both cooling and warming applications.
The CoolGard 3000 system is used in hospitals around the world and referenced in over 50 publications since its introduction in 2002. The CoolGard System is trusted by physicians to safely, precisely and rapidly cool their critically ill or surgical patients.
The target temperature and rate of temperature change are set on the CoolGard 3000 system which controls the temperature of the saline flowing within the Alsius Catheter balloons. Patient and system data are automatically sampled every 60 seconds and a change in patient temperature as small as 0.01°C triggers an immediate adjustment in the saline temperature.
FORUMSView All (4)
-MOJIOY
4 years ago
Errors 11 and 26
Hi there! Do any body know about error "M id:11" And "M id:26" Or how to clean/ skip errors? Thank you!Reply
-Peggy Berkey
8 years ago
Competency
Do you have a competency/skills check off for nurses using the Zoll Alsius CoolGuard?
-RVanegas
10 years ago
MD
Do you recommend the use of  the Max-Power mode in the CoolGuard 3000 to treat  a mild hyperthermia of 38.4 degree Celsius after 48 hours  of rewarming or the Controlled Rate mode or none of them ?
Thank you,
Dr. R.Vanegas
SERVICE COMPANIESView All Warming/Cooling Unit Companies
  • Pre-warm function
  • Standby Timer Alert
  • Automatic T2 Detection (Second Temperature Probe)
  • Streamlined set-up
