Unisyn Medical Technologies, Inc. - iTest
by Unisyn Medical Technologies, Inc.
Specifically designed to test the electrical safety of all types of diagnostic ultrasound transducers
The iTest and iTest PRO are specifically designed to test the electrical safety of all types of diagnostic ultrasound transducers, totally independent of the ultrasound machines on which they are typically used. Although the iTest and iTest PRO can be used on virtually any type of ultrasound transducer, they are especially recommended in the testing of TEE (Transesophageal Echocardiography) transducers prior to each use; as recommended by TEE ultrasound device manufacturers. The iTest™ and iTest PRO™ test the integrity of the outer insulation barrier of the transducer as well as the capacitive leakage currents that exist.            The iTest and iTest PRO are the most advanced instrument of their kind on the market today and add a totally new dimension to diagnostic ultrasound transducer electrical safety testing. With features and functionality that far surpass competitive products from other manufacturers, the iTest ™ and iTest PRO™ are easy to set up and use. Operating modes include a simple PASS/FAIL mode as well as a QUANTITATIVE mode that offers actual readings. The iTest™ and iTest PRO™ can also print test results to an optional printer. Compatibility with Dale Technology DALE601, Fluke Biomedical ULT800 adapters and Dual Conductivity Probes allow you to upgrade to the very latest technology platform, while safeguarding any prior investment in adapters and probes.
-mdwinn
Fri Aug 23 2019
Output voltage LOW at 200 and 250V
I have a iTest Pro and the Output Voltage is Out of Spec at 200 and 250V 60 Hz. Is there an adjustment procedure?Reply
[list]      [*] Large graphics display with cursor selection of options and setup parameters.      [*] User selectable challenge (test) voltage, 90 to 275 VAC.      [*] User selectable challenge (test) frequency, 50 or 60 HZ.      [*] User selectable test limits by transducer manufacturer and model.      [*] 1% FS measurement accuracy      [*] Automatic internal self test      [*] Single button activated full system test      [*] Simple Pass/Fail mode available      [*] Analytical mode available  [*] Digital calibration      [*] User selectable display options      [*] Battery life display (0% to 100%)      [*] Programmable backlight timer      [*] Adjustable contrast      [*] Upgradeable firmware      [*] RS232 port and PC software available      [*] Printer output port with programmable user header      [*] Real time clock      [*] Compatible with Dale technology and Fluke transducer adapters and dual conductivity probes.      [*] Meter mode (iTest Pro™ only)  [*] Programmable challenge (test) voltage and frequency (iTest Pro™ only)  [*] Programmable meter timer (iTest Pro™ only)  [*] Datalog with storage of 99 test records (iTest Pro™ only)  [/list]
Analyzer/Simulator TypeUltrasound
