REXMED - ROL-501S
by REXMED
MOD. ROL-501S, AC 100~240V, Plug Type: , Surgical Lamp, HS CODE: 940520, UNCCS CODE: 486304, UMDNS CODE: 12282, GMDN CODE: 32240, Main construction: cast aluminium and powder coated steel, Mobile stand type 4 castors with 2 lockable castors, Single dome surgical lamp, Lamp head: 62cm with 4,760 lenses / transparent lenses polycarbonate reflector, Reflector: 50cm aluminium 160 layers reflector and 8pcs filter, Bulb specification: OSRAM 24V 150W x 3pcs (1 primary and 2 backup X 1set), Bulb life time: 3,000 hrs ±10%, Colour Temperature: 3,800/4,300/4,500K ±200K, CRI: 94 ±3, Working distance: 60~180cm, Depth of light (L1+L2): 120cm, Intensity: 0~80,000/100,000/150,000 Lux/1m, Focus: 15~25cm by sterilizable handle, light field: d10=15cm, d50=8cm, Remaining intensity / EC with one mask: 23%, with two masks: 48%, with one tube: 97.5%, with one mask and one tube: 23%, with two masks and one tube: 48%, Swivel radius: movement, Lamp head elevation: 105cm 15°up/75°down, Lamp head rotation: 360°, Controller: ON/OFF switch, intensity 0~100% by 1% and 10% dimmer control on copula and infrared remote controller, Auto switch over to spare bulb < 0.1sec when main bulb failure: Yes, Surgeon head temperature increase < 2°C, Radiation energy: < 3mW/m².lux, W/S: Light bulb X 1pc, I.R. remoter controller X 1pc, Sterilizable handle X 2pcs
| Bulb Life | 3000 hr |
| Depth of Field | 120 cm |
| Color Temperature | 3800 K /4,300/4,500K ±200K |
