REXMED - RIT-350
Incubator
MOD. RIT-350, AC 110/230V, Plug type: , Low temperature incubator, HS CODE: 993199, UNCCS CODE: 484326, UMDNS CODE: 18013, GMDN CODE: 35482, Main construction: powder coated steel and SS304, Controller: Microprocessor based PID controller, water proof keypad with timer, °C/PV and °C/SV display and setting, Timer: 9999/min, 9999/hr, Timer has DELAY_ON and DELAY_OFF function at the end of operation audio and visual warning, Working range: +5°C~60°C, Stability at 37°C: ±0.1°C, Uniformity: ±0.5°C, Sensor: PT 100Ω, Temperature audio and visual warning for AL-H and AL-L and OFS correction setting, Heater: 700W, Cooling compressor: 1/10HP, Compressor has delay on and overload protection, auto defrost setting, Cooling capacity: 95 Watts, 325 BTU/hr, 82 Kcal/hr, Chamber: L66 X W60 X H142cm, Capacity: 562L, inner glass viewing window, 4 castors, W/S: shelf X 4pcs
