REXMED - RIT-450
Incubator
MOD. RIT-450, AC 230V, Plug type: , Temperature gradient incubator, HS CODE: 993199, UNCCS CODE: 484323, UMDNS CODE: 18013, GMDN CODE: 35482, Main construction: powder coated steel and SS304, Controller: Microprocessor based PID controller, water proof keypad with timer, °C/PV and °C/SV display and setting, Timer: 24hr, Timer has DELAY_ON and DELAY_OFF, 24hrs day and night time temperature control setting function, Working range: 0°C~50°C, Stability at 37°C: ±1°C, Uniformity: ±1°C, Sensor: PT 100Ω, Temperature audio and visual warning for AL-H and AL-L and OFS correction setting, Heater: 300W X 5, Cooling compressor: 1/3HP, Compressor has delay on and overload protection, auto defrost setting, Cooling capacity: 1,386 Watts, 4,730 BTU/hr, 1,194 Kcal/hr, Chamber: L45 X W45 X H24cm X 5, Capacity: 243L, chamber with fluorescent lamp X 6pcs (10,000Lux), day and night or all day time lamp on control setting function, and inner acrylic viewing window, chamber temp can be set 2~8°C difference, 4 castors
