REXMED - RIT-501
by REXMED
Incubator
MOD. RIT-501, AC 230V, Plug type: , Growth chamber, HS CODE: 993199, UNCCS CODE: 484382, UMDNS CODE: 18013, GMDN CODE: 35482, Main construction: powder coated steel and SS304, Controller: Microprocessor based PID controller, water proof keypad with timer, °C/PV and °C/SV display and setting, Timer: 24hr, Timer has DELAY_ON and DELAY_OFF, 24hrs day and night time temperature control setting function, Working range: +5°C~40°C, Stability at 37°C: ±0.15°C, Uniformity: ±0.15°C, Sensor: PT 100Ω, Temperature audio and visual warning for AL-H and AL-L and OFS correction setting, Heater: 700W, Cooling compressor: 1/2HP, Compressor has delay on and overload protection, auto defrost setting, Cooling capacity: 1,610 Watts, 5,490 BTU/hr, 1,385 Kcal/hr, Chamber: L66 X W58 X H142cm, Capacity: 470L, chamber with fluorescent lamp X 12pcs 3shelves (8,000Lux), day and night or all day time lamp on control setting function and double glass viewing window, 4 castors, W/S: shelf X 4pcs
