REXMED - RIT-601
Incubator
MOD. RIT-601, AC 230V, Growth chamber, HS CODE: 993199, UNCCS CODE: 484382, UMDNS CODE: 18013, GMDN CODE: 35482, Main construction: powder coated steel and SS304, Controller: Microprocessor based PID controller, water proof keypad with timer, °C/PV and °C/SV, %RH/PV and %RH/SV display and setting, Timer: 24hr, Timer has DELAY_ON and DELAY_OFF, 24hrs day and night time temperature and humidity control setting function, Working range: +5°C~40°C, Stability at 37°C: ±0.15°C, Uniformity: ±0.15°C, Humidity: 50%RH~95%RH, Humidity Accuracy: ±2%RH, Humidifier: Ultrasonic type, Sensor: PT 100Ω, Temperature and humidity audio and visual warning for AL-H and AL-L and OFS correction setting, Heater: 700W X 2, Cooling compressor: 1.25HP, Compressor has delay on and overload protection, auto defrost setting, Cooling capacity: 4,550 Watts, 15,515 BTU/hr, 3,913 Kcal/hr, Chamber: L125 X W58 X H142cm, Capacity: 504L, chamber with fluorescent lamp X 18pcs 3shelves (16,000Lux) day and night or all day time lamp on control setting function and double glass viewing window, 4 castors, W/S: shelf X 4pcs
