Carestream - DirectView Elite CR
Small single-plate CR reader.The DIRECTVIEW Elite CR System is designed for distributed and central CR applications where image quality, rapid image availability, lower costs and high departmental productivity are paramount.
FORUMSView All (7)
0Repliesa year ago | Standby lamp not lit Good day, i need help the CR scanner, ti cannot communicate with the software and standby lamp was off. Thank youReply |
1Replya year ago | Error: The cassette has failed to load Good day, i need help the CR scanner error. Thank youReply |
0Repliesa year ago | Standby light not lot Good day, I need help on our scanner, scanner cannot be detected by the software, stand lamp is also off. Thank you.Reply |
[list] [*] Produces high quality images with a footprint that is compact enough to be placed in an x-ray room or control console room. [*] Integrates a central database with multiple workstations to improve workflow, productivity and patient throughput. [/list]
Weight | 300 lbs |
CR-Workstation Configuration | Optional device for one or more image readers |
CR-System Configuration | Single-plate floor unit |
Mammography Support | 1 |
Scoliosis Imaging | 1 |
Throughput (@ 14x17, std resolution)98 plates per hour Image plate DQE -- percent at 2 lp/mm Reader laser spot size -- microns Output grayscale resolution 12 bits/per pixel Preview image display time33 seconds
NEWSView All
Carestream Introduces New Features for Its DIRECTVIEW Elite CR,...
Carestream debuted new software features for three of its computed radiography systems that offer important advantages in the areas of quality and exposure control, pediatric and ICU imaging and print output.
