Carestream - DirectView Vita CR
Compact, tabletop CR readerThe Vita CR System is an affordable, compact, tabletop imaging solution designed specifically for small hospitals, clinics and specialty practices. [list] [*] Compact footprint fits easily into small areas [*] Light weight and portable makes it ideal for mobile units [*] Simple integration into your current workflow [/list]
FORUMSView All (29)
1Reply6 months ago | Carestream Image Suite Please how can i get Carestream Image Suite for DirectView Vita CR, i also need rollers for the same machine Reply |
1Replya year ago | malfunction with cassette process error codes 5, 22 also linear motor homing any ideas what may be causing this and fix Equipment: carestream directview vita cr Reply |
0Repliesa year ago | Image scanning is fine but no image appears Scaning process is fine, scan, erase and eject but at the end of the scanning process no image appears, it even a white or black image. This happens for all the cassetes. Please can anyone advise? Equipment: Carestream - DirectView Vita CR Reply |
[list] [*] 79 lbs. – smaller and lighter than other CR solutions [*] Durable design – holds up in extreme conditions [*] Easy to use interface [*] Small footprint makes it easy to transport [/list]
Weight | 79 lbs |
CR-Workstation Configuration | Not Available |
CR-System Configuration | Single-plate table unit |
Mammography Support | 0 |
Scoliosis Imaging | 1 |
Throughput (@ 14x17, std resolution) 44 plates per hour plates per hour
NEWSView All
Carestream Announces Enhanced Image Acquisition Software For Its...
New Features Enhance Workflow, Offer Advanced Processing Tools
