Kodak - Point-of-Care 140
by Kodak
CR system
The POINT-OF-CARE CR 140 System is ideal for computed radiography examinations in busy clinics and specialty practices. Recommended for satellite locations such as military field installations, CR 140 provides big value. Durable, compact, and lightweight, CR 140 enables all imaging functions to be performed at the point of patient care with one affordable package featuring: the single-plate CR reader, flexible phosphor screens, advanced image management software, and a PC-based review station.
FORUMSView All (24)
-MikeKryg
Wed Jan 11 2023
Point of Care CR140
Service: Looking for assistance for ZO sensor and roller adjustment for unit. Located in Farmington Hills MI 248-324-3090 MikeReply
-MikeKryg
Mon Apr 18 2022
Need Service in Michigan
Have a Kodak Point of Care 140 and it will not turn on and film is still in machine. Call office 248-324-3090 to set up appointment to fix problem. Live in Farmington Hills, MIReply
6
-DCrtr
Tue Jul 27 2021
Repair technicians
I have a Kodak Point of Care 140 scanner that needs to be repaired. Are their any service companies in the Washington, DC area?Reply
  • Highly versatile- The POINT-OF-CARE CR 140 System is part of a modular solution that can be configured to meet most clinical applications. Its Quality Control Scanner interface lets you set up the system to capture high-quality x-ray images of any body part with minimal steps for scanning, processing, and image quality assurance. All imaging parameters are optimized, resulting in digital images that can be enhanced, enlarged, duplicated, and sent to any location in seconds as a DICOM 3.0 file with no loss of resolution. Images also can be printed or archived locally on CDs or DVDs
  • Productivity-  Mounted on an optional wheeled Z-cart or placed on a tabletop, the POINT-OF-CARE CR 140 System can be used in virtually any location. With the Z-cart, this system can be rolled into any situation where nearly instant digital images are needed.
  • Military applications-   Deployed by military forces worldwide, the field-proven POINT-OF-CARE CR 140 System is ideal for remote locations. Its durable design can withstand rough handling, temperature and humidity extremes, and stresses of nature such as wind, sand, and moisture. Even in the most demanding conditions, this portable system is easy to set up and operate.
Height13.4 in
Length 25.8 in
Weight99 lbs
CR-Workstation ConfigurationNot Available
CR-System ConfigurationMulti-plate table unit
Mammography Support1
Width29 in
  • Throughput- Up to 40 cassettes per hour (14 x 17 in.)
  • Grayscale Resolution -  Acquisition: 12 bits per pixel Display: 12 bits per pixel
