Fujifilm - FCR Carbon XL-2
by Fujifilm
Computed Radiography System
The Carbon XL-2 is ideal for distributed applications such as inside the exam room or even a trauma bay with a speed of up to 92 images an hour and image previews in as little as 23 seconds. With that flexibility, the Carbon XL-2 is also a great redundancy solution during peak periods. The XL-2 also features a 50 Reading Mode* for sharp, excellent detail  ideal for extremity exams or anywhere that seeing fine details is critical.        The Carbon X is designed for smaller facilities with variable caseloads or remote applications with throughput speeds of up to 72 images/hour. It can supplement a DR room or offer redundancy when needed. Either way, there's a FCR Carbon to fit your needs and your space perfectly.
FORUMSView All (30)
-DSX57
2 years ago
Fujifilm FCR XL-2 error code 10323
When powering it goes through mechanical initialization and shows the error 10323 requesting shutdown. Any suggestions. Service manual (if anyone can email) will be greatly appreciated. Thanks. Duke email: duke.dsxtech@gmail.comReply
-Kingsleyek
3 years ago
System down error 10320.
Please how do I correct system down error 10320 ? It shows 'shutting down the system ' during booting.Reply
-portwood56
3 years ago
fuji fcr carbon xl-2
Service manual needed.Reply
[list]    [*] Fast image previews beginning in as little as 10 seconds    [*] Quick throughput - XL-2: 62-92, Fast Scan mode: 87 images/hr 14x17" X: 43-72 images/hour    [*] 100 micron 10 pixels/mm Standard Reading Density    [*] Image Reading 12 bits gray scale, output: 10 or 12 bits    [*] Small 2.4 sq. ft. footprint    [/list]
Height31.9 in
Length 15 in
Weight216 lbs
CR-Workstation ConfigurationIncluded device for one or more image readers
CR-System ConfigurationSingle-plate floor unit
Mammography Support0
Scoliosis Imaging1
Width23.2 in
Throughput (@ 14x17, std resolution) 87 plates per hour    Image plate DQE Proprietary percent at 2 lp/mm    Reader laser spot size50 & 100 microns    Output grayscale resolution 12 bits/per pixel    Preview image display time 3 seconds
