Fujifilm - ClearView-CS and ClearView-1
by Fujifilm
ClearView systems feature higher DQE and clearer images with less noise. These advanced imaging systems also offer higher spatial resolution for better visualization of fine details. Also standard single side reading for routine general radiographic examinations is supported.
4RepliesMon Jun 14 2021 | ERROR 10398 EN CR FUJI CLEARVIEW HOLA, TENGO UN ERROR 10398 EN UN CR FUJU QUIEN ME PUEDE AYUDAR A ESTE PROBLEMAReply |
0RepliesThu Feb 07 2019 | QC Calculation Tool Error When attempting to do mammography QC, message on screen reads "Failed in obtaining study information from the information file". Can someone tell me what this message means and what needs to be done to correct the issue? ThanksReply |
1ReplySat Dec 15 2018 | alive55 Looking for service manual for Fuji Clearview-1MReply |
[list] [*] 30-40% higher DQE over standard single side scanning [*] 50 micron scanning for higher spatial resolution [*] Potential dose reduction [*] Ideal for pediatrics, extremity work - anywhere that seeing the details matters! [/list]
| Height | 58.2 in |
| Length | 29.1 in |
| Weight | 627 lbs |
| CR-Workstation Configuration | Included with each image reader |
| CR-System Configuration | Multi-plate floor unit |
| Mammography Support | 0 |
| Scoliosis Imaging | 1 |
| Width | 25.8 in |
Throughput (@ 14x17, std resolution) 103 std or high-res plates per hour Image plate DQE Proprietary percent at 2 lp/mm Reader laser spot size 100 or 50 microns Output grayscale resolution12 bits/per pixel Preview image display time 15-25 sec (fully processed) seconds
