Fujifilm - XG5000
The XG5000 is fast, efficient and reliable.With four independent cassette insertion drivers, this high-performance system is perfect for centralized imaging, multiple exam rooms or any busy environment. Throughput speeds of up to 165 images/hour and image previews in as little as 23 seconds put the XG5000 at the top of its class.
FORUMSView All (11)
0Replies7 months ago | Spare parts I want a lcd for xg 5000 cr ir 362 and service manual ...and vaccum pump ...and vaccum cup ... Equipment: Fujifilm - fcr xg5000 Reply |
1Reply2 years ago | Password I need to manage DICOM settings but dont know the password do access the system. ThxReply |
11Replies4 years ago | Image signal error code 11287 Hello, can anyone please help me with the fix of this Error code 11287, (image signal error) , I have tried reinstalling the ru also, it won't complete, I keep getting in the installing software cmd promt the following. -LOGIN OR PASSWORD INCORRECT -can't open "RDISK/SYSTEM/.../LOG/STATISTICS/HISTORY.CFG I REALLY IM GRATEFUL FOR AN ASSISTANCE. Reply |
- Small footprint of only 5.3 sq. ft.
- Fast image previews beginning in only 11 seconds
- Complete a two-view exam in just over a minute
- Built-in redundancy of independent cassette insertion drives - if one slot fails, use one of the others!
Height | 58.2 in |
Length | 29.7 in |
Weight | 627 lbs |
CR-Workstation Configuration | Included with each image reader |
CR-System Configuration | Multi-plate floor unit |
Mammography Support | 0 |
Scoliosis Imaging | 1 |
Width | 25.8 in |
Throughput (@ 14x17, std resolution) 103 standard or high-res plates per hour
Image plate DQE Proprietary percent at 2 lp/mm
Reader laser spot size 100 microns
Output grayscale resolution Proprietary bits/per pixel
Preview image display time15-25 (fully processed) seconds
