iCRco - iCR3600
Singe-plate CR readeriCR3600 will transform your practice into a modern imaging facility. iCRco computed radiography equipment provides exceptional image quality, high through put and low cost of ownership. Although computed radiography technology has been widely accepted, all major manufacturers follow the same pattern of removing the costly phosphor plates and running them through rollers in their CR readers, we have re-invented how CR technology works with True Flat Scan Path ™. This technology ensures the phosphor plate never leaves the cassette to avoid any plate handling, damage or wear during the scan process, making 300,000+ images per plate a reality.
FORUMSView All (3)
2Replies4 years ago | user name and password ia forgot a passwor and user name /ia cant work please helpReply |
7Replies7 years ago | Anatomical program is there any possibility to edit the settings of anatomical programs on the system ?Reply |
1Reply8 years ago | Full erase function When our film comes out it goes super slow we were told the full erase may be on that's why it takes so long to come out. How can I check that and undo it if that's the case? Reply |
* Only wall mountable CR [list] [*] True Flat Scan Path™ [*] One moving part [*] 300,000 images per plate [*] DR quality images with CR versatility [*] Easy integration to any X-ray room [/list] [i]In addition, iCR3600 is the true meaning of an integrated solution paired with the touch screen capable superior image processing software Captera.[/i]
Weight | 78 lbs |
CR-Workstation Configuration | Included with each image reader |
CR-System Configuration | Single-plate table unit |
Mammography Support | 1 |
Scoliosis Imaging | 1 |
Throughput (@ 14x17, std resolution) 70 plates p/hour plates per hour Reader laser spot size 50 microns Output grayscale resolution 16 bits/per pixel Preview image display time25 seconds
