Philips - PCR Eleva S
Small, compact single slot reader with 78 plates/hour throughput for moderate performance needs2With PCR Eleva systems you can digitize your conventional X-ray rooms. Each PCR Eleva system can be used for a wide range of applications. The PCR Eleva S is the smallest family member. It is a compact, single-slot system which allows a throughput of 78 plates per hour or a cycle time of 46 seconds. PCR Eleva S is suitable in environments with moderate performance requirements, for private practices, a one-room solution with low CR throughput or as a backup reader.
FORUMSView All (6)
0Replies7 months ago | DICOM Media License Hi All, Does anybody know how I would go about getting a DICOM Media License on a PCR Eleva S. Would this enable the writing of CDs? Reply |
1Reply4 years ago | Not Removing Cartridge. We have a PCR Eleva S. The tech put a cassette in and had to manually pull it out. She then tried another and now the machine will not suction on and pull the cartridge out. Can you help on this issue? What do I look for?Reply |
2Replies6 years ago | Install software Pcr install software on pc work station but error in pcr reader can not process cassette when try to install pcr reader software on pc Reply |
PCR Eleva S supports a wide range of applications: [list] [*] Intensive care units, where free exposure techniques and fast image transmissions are required [*] Trauma departments, where fast and simple operations and initial on-screen findings are required due to time constraints [*] Orthopedics, where long image formats are required [*] General X-ray, with its wide range of projections and diagnostic requirements [*] Dental applications [/list]
Weight | 193 lbs |
CR-Workstation Configuration | Included with each image reader |
CR-System Configuration | Single-plate floor unit |
Mammography Support | 0 |
Scoliosis Imaging | 1 |
Throughput (@ 14x17, std resolution) 78 plates per hour Image plate DQE 14 percent at 2 lp/mm Reader laser spot size Oval shape, 60 by 70 µm microns Output grayscale resolution 12 bits/pixel (4096 grey levels) bits/per pixel Preview image display time 53 seconds
