Olympus - CLV-160
by Olympus
Improved condenser lens design and powerful 300W xenon lamp.
With its improved condenser lens design and powerful 300W xenon lamp, the EVIS EXERATM 160 Series' dedicated light source, the CLV-160, is able to generate 30% more light intensity than its predecessor, the CLV-U40. This new design and power assures clear, accurate observation even of distant points. When combined with the CV-160 video system center, the CLV-160 provides a system that is a full 80mm narrower and 35% smaller than previous Olympus models, allowing for the entire system to be installed on a dedicated cart together with a video monitor and other ancillary equipment.
FORUMSView All (5)
-African boss
2 years ago
Torrent display board
Why is my display face having a blinking light thus making me not able to use the buttons to set sth.
Equipment: Olympus - CLV-160
-Evolution Vet
4 years ago
scopes
New to the whole Olympus scopes world. I cant seem to find anywhere that tells me what scopes are compatible with my unit. I have the CLV 160 and the CV 160 in my tower and I have a couple of scopes that the salesman sold to me along with it (all used refurbished). It all works great and I want to add to the system but cant find any digestible info on what I can add as far as scopes and KNOW that it works with my setup. Reply
2
-Clifani
5 years ago
Help me
I can't get voltage to the pump what could be the possible solution Reply
[list]        [*] Powerful 300W xenon lamp for Olympus color CCD videoscope system        [*] New and improved condenser design helps achieve nearly 1.3x as much light intensity as the CLV-U40        [*] User-friendly front panel design        [*] Illumination capability to cover even more distant points assures sufficient brightness when retroflexing the scope tip, observing the lower esophagus, and more        [*] Improvement in light adjustment levels helps maintain appropriate brightness even when observing at extremely close range or observing the gastric angulus        [*] 35% reduction in overall size compared to its predecessor, with width reduced by a full 80mm, saving space in your endoscopy suite        [*] Simple membrane switches and clear indicators on the front panel for improved operability        [*] Compatible with conventional Olympus color CCD videoscopes and fiberscopes        [*] Electronic lamp light indicator         [/list]
