Datrend - Infutest Solo
by Datrend
The Infutest Solo from Datrend is a compact, high-performance infusion pump analyzer designed to simplify and streamline infusion device testing in clinical engineering environments. With internal memory capable of storing up to 120 tests, Infutest Solo is perfect for field service, preventive maintenance, and equipment validation.
As part of the Datrend ES601 Plus System Connectivity Family, the Infutest Solo seamlessly integrates with the ES601 Plus Automated Safety Analyzer, enabling access to 12 customizable IV pump autosequences. Each auto sequence is fully editable, allowing biomedical engineers to tailor test protocols to their specific device inventory. (Generated by AI)
Built-In Memory: Store up to 120 test results internally for batch testing and offline reporting
ES601 Plus Integration: Unlock full autosequence capability via Datrend’s ES601 Plus System
Customizable Autosequences: Easily adapt predefined test protocols to match your unique pump fleet
Flexible Data Entry: Input device information manually via front panel keypad or use an external barcode scanner for fast ID capture
Easy Data Transfer: Download stored test data to your PC using USB or RS232 with Infutest Solo Utility Software
Compact & Efficient: Ideal for on-site testing, mobile biomedical service teams, or in-house clinical engineering (Generated by AI)
| Analyzer/Simulator Type | Infusion Device |
