Datrend - Sensitest
by Datrend
Sensitest is a compact, easy-to-use solution designed for biomedical engineers and clinical technicians to quickly verify the functionality of all types of SpO‚ probes across various patient monitoring systems. Ideal for use in clinical, hospital, and biomedical environments, Sensitest ensures reliable performance checks with a simple plug-and-test workflow.
With universal compatibility and no complicated setup, Sensitest streamlines routine SpO‚ sensor validation, helping improve patient safety and reduce downtime for medical equipment. (Generated by AI)
Compatible with All SpO‚ Probes – Supports a wide range of pulse oximeter sensors from leading manufacturers
Plug-and-Play Simplicity – Just connect the probe, read the result, and you're done—no calibration required
Ideal for Clinical & Biomedical Use – Designed for hospital biomeds, ISO field service engineers, and manufacturers
Reliable Results in Seconds – Quickly identifies defective or out-of-spec probes to ensure optimal monitoring performance
Maintenance-Friendly – Portable and durable, perfect for preventive maintenance and on-site troubleshooting (Generated by AI)
| Analyzer/Simulator Type | Pulse Oximeter |
