Fluke Biomedical - ESA612
by Fluke Biomedical
One-touch testing
The ESA612 Electrical Safety Analyzer is a next-generation, all-in-one testing solution specifically designed for biomedical engineers and clinical engineering professionals conducting on-site medical equipment service. Ideal for use in hospitals, clinics, and field environments, this portable and lightweight analyzer combines the functions of an electrical safety tester, multimeter, and patient simulator in one compact device.
Engineered for tight-space operation and global standards compliance, the ESA612 offers selectable test loads for flexible use across multiple regions. It supports electrical safety testing to IEC 60601-1, IEC 62353, and ANSI/AAMI standards, making it a trusted tool for preventive maintenance and regulatory compliance.
Enhance productivity with Ansur automation software, which streamlines testing, standardizes procedures, and enables seamless data management—from real-time pass/fail comparison to automated report generation. (Generated by AI)
-MedWrench Intern
Sun Jun 24 2018
ESA612 Demonstration Video
ESA612 Demonstration VideoReply
-sk05853
Fri Nov 11 2016
User Manual
VIDEOS
[list]  [*] Portable, ergonomic, lightweight, and easy to use  [*] Large, easy-to-read display with adjustable contrast  [*] Human-factors-designed user interface  [*] Tilt stand design for stand-up testing in field environments  [*] Five applied parts jacks and easy ECG snap connection with optional expander box  [*] ECG waveform tests and dual-lead measurements combine the functionality of a simulator, multimeter and safety analyzer in a single test tool  [*] Replaceable mains fuses keep your unit in the field and out of the repair shop  [*] Internal memory for 100 test records  [*] 20 A at 120 V current capability  [*] USB connection for use with Ansur and Data Viewer software (for memory download to PC)  [/list]
Height11.2 in
Length 3.3 in
Weight3.5 lbs
Analyzer/Simulator TypeElectrical Safety
Current Range0 to 20 A
Voltage Range90 to 132 V
Width6.94 in
