Fluke Biomedical - ESA620
by Fluke Biomedical
Easy Comprehensive Testing
The ESA620 Electrical Safety Analyzer is a next-generation portable, manual electrical safety tester designed specifically for biomedical technicians and clinical engineers performing safety checks on medical equipment. Engineered for versatility, the ESA620 supports global electrical safety standards such as IEC 60601-1, IEC 62353, ANSI/AAMI ES1, and NFPA-99, making it ideal for use in hospitals, labs, and field service settings worldwide. (Generated by AI)
FORUMSView All (7)
-Pepino67
Sat May 10 2025
Fault Detected
if somebody can help me ...the screen said
Fault detected...
Mains out of range
-DFMK6
Thu Mar 21 2019
Case removal
How do you remove the casing to get access to the board? I need to resolder the data port. Thank you.Reply
-Alain Mancera
Wed Jun 21 2017
Initialization Error during boot up
When powered on it starts to boot up and then says "Fault Detected. Initionalization Error", Serial number of equipment is 1994035. Also screen is half dark the right side and somewhat bright the left side. What can it be for both problems?Reply
  • Global Standard Compliance: Three selectable test loads, multiple insulation test voltages (250V and 500V), and protective earth test currents for flexibility in various international test protocols.
  • Advanced DSP Technology: Ensures highly accurate leakage current measurements and reliable safety testing in compliance with medical device standards.
  • ECG Simulation: Ten ECG posts simulate performance waveforms for combined electrical safety and basic patient monitor testing.
  • Enhanced Connectivity: Built-in USB interface for PC control and seamless data transfer; compatible with Ansur software for automated test sequences, data capture, and standardized reporting.
  • High-Current Capability: US version includes a 20-A receptacle to test high-draw medical devices—exceeding the 15-A limitation of many analyzers. (Generated by AI)
Height10 cm
Length 23 cm
Weight4.7 kg
Analyzer/Simulator TypeElectrical Safety
Current Range0 to 20 A
Width31 cm
