Medtronic - CryoConsole
by Medtronic
The CryoConsole is the device that powers the Arctic Front® Cardiac CryoAblation Catheter and the Freezor® MAX Cardiac CryoAblation Catheter. The console houses the electrical and mechanical components and software needed to perform cryoablation procedures. It controls the delivery, recovery, and disposal of cryoablation refrigerant safely and efficiently. [b]How the CyroConsole Works[/b] The CryoConsole safely manages the delivery, recovery, and disposal of N2O during cryoablation procedures. Its components and software operate the Arctic Front Advance Cryoballoon system and Freezor MAX catheters, and provide continuous monitoring ensuring system safety. [b]Perform and Monitor, Cryoablation Procedures[/b] During a cardiac ablation procedure, pressurized liquid nitrous oxide (N2O) is delivered from a tank in the CryoConsole. The liquid refrigerant travels in an ultra-fine tube through the coaxial umbilical and the shaft of the cryoablation catheter to the tip of the catheter. The liquid refrigerant vaporizes as it is sprayed into the tip. As it vaporizes, it absorbs heat from the surrounding tissue, thereby cooling and freezing the target tissue. The warmed refrigerant is vacuumed back to the CryoConsole through a large lumen within the shaft of the catheter and coaxial umbilical. The CryoConsole discharges the vapor into the hospital scavenging system.
0RepliesThu May 29 2025 | service manual PM requirement Equipment: CryoConsole 10000-008-08 Reply |
0RepliesSat Oct 29 2022 | PM:Tech 106A3 CryoConsole Cardiac Cryoablation Looking for a tech that is can PM a 106A3 CryoConsole Cardiac Cryoablation. Site Location: Orlando, Florida Reply |
1ReplyThu Oct 14 2021 | Not able to download manual Unable to download i only recieve the spinning gear icon. I have tried on different browsers and devices, no luck :( https://www.medwrench.com/documents/view/2244/medtronic-cryoconsole-service-manual Reply |
| Height | 157 cm maximum height; 126 cm minimum hight |
| Length | 59 cm |
| Weight | 131 kg without nitrous oxide tank |
| Width | 55 cm |
