Nical - N23
Camera for x-ray image intensifierThe N23 camera offers a 10 bit digital image, characterized by high resolution. The innovative feature of this camera is the possibility to have a dynamic recursive filter operating at single pixel level. The filter enables eliminating any photonic noise significantly, as if using a standard recursive filter, and also manages to eliminate any image dragging during the patient's movement. The CCD sensor used for this product delivers an optimum gamma curve which ensures excellent quality levels in high-contrast images. The same sensor is also used in interline mode, an extremely useful and much appreciated features during a pulsed fluoroscopy at 25 frames per second.
1Reply10 years ago | ABC control intermitent The signal on CCU connector J0 pin 16 (Analog control) is intermitent Reply |
CCD Camera Head
High resolution Charge Coupled Device sensor(CCD)
Video preamplifier
Pulses and sync generator
Power supply circuitry to CCD camera head
Image rotation system (optional) 360°
Standard lens system
The camera head is connected to the camera control unit by means of an extremely flexible, small diameter (6mm) cable, which may be several tens meters in length
White spot erasing (option)
Control unit (CCU RACK)
Main power supply: 20?30Vdc input
Video processing and output amplifier
Analog and digital output automatic kV or mA control circuit
Electronic circle generator (picture delimitation)
Digital recursive filter for noise reduction, with DRF (Dynamic Recursive Filter)
Horizontal and vertical image inversion
Video output standard 625/525, 1249/1049, 625-100Hz or 525/120Hz
Options: Up to 512 frames memory with two independent digital out channels.
Option: User friendly interface with icons for operation running
