STERIS - 4085
by STERIS
Surgical Table
The STERIS 4085 General Surgical Table's design gives a surgical team the flexibility, control and convenience they need for today's patients and procedures.
1Reply7 months ago | Steris 4085 floor locks digging thru the maintenance manual to no avail. Remember when we used to get actual schematics, wiring diagrams, theory of operation? so i can hear the pump move when I engage the floor locks, however they're not moving. all 4, so i'm suspecting the manifold instead of the individual floor locks, but don't want to rule out the power supply. Has anyone run into this? Reply |
1Reply2 years ago | error 24 on a steris 4085 is there anyone here that tell me what an error 24 on a 4085 is and possibly be able to send a service manual thank you robert@reosmedical.comReply |
2Replies3 years ago | Charger defect error F1; F2 and battery fuses are working. What could be the problem?Reply |
Height | 26 in to 45 |
Length | 81 in |
Weight | 560 lbs |
Tredelenburg | 30 degrees |
Lateral Tilt | 20 degrees |
Patient Weight Capacity | 1100 lbs patient support, including raise/lower (centered on the column) |
Width | 20 in |
Head Section +90° to -90°
Back Section +80° to -40°
Leg Section 0/-105° (removable)
Flex/Reflex 140° / 100°
Manual Override Yes
Perneal Cut-out Yes
Kidney Elevator 4" powered radiolucent
