Syneron-Candela - AlexTriVantage
by Syneron-Candela
With its unique Laser–Pumped–Laser technology Alex TriVantage is a perfect addition to your practice.. Beyond improving the results you get from your existing fractional and rejuvenation devices, Alex TriVantage with its 755, 532 & 1064 nm wavelengths brings exciting new treatment capabilities to your office – from unsurpassed pigmented lesion removal to treatment of tattoos of all colors. [b]Alex TriVantage - So versatile, you’ll use it on practically every patient you see. [/b]
1ReplyWed Oct 18 2023 | Candela ATV umilical repair Need part or repair of Candela Trivantage handpiece-end umblical spring-tension contact. (504) 228-3959 Reply |
5RepliesThu Dec 10 2020 | Fibers Looking for someone who can repair or rebuild the fibers Reply |
1ReplyThu Jun 27 2019 | Manual Can I access to download the manual for this machineReply |
[list] [*] Flexible, lightweight fiber-optic delivery system [*] Comfortable, ergonomic handpieces [*] Treatment spot sizes from 2-5 mm and repetition rates up to 5Hz [*] Aiming beam and redesigned distance gauges [*] Fast and easy touchscreen user interface [*] Convenient portability between treatment rooms [/list]
| Laser Type | Alexandrite |
| Height | 43 in |
| Length | 30 in |
| Weight | 290 lbs |
| Wavelength | 755 nm ,532, & 1064 |
| Width | 16 in |
