Syneron-Candela - GentleLASE Pro
by Syneron-Candela
[b]Leading Technology, Re-Imagined.[/b] GentleLASE PRO represents the re-imagination of the aesthetic industry’s premier laser for removing hair, epidermal pigmented lesions and wrinkle reduction. It’s faster and loaded with advanced features that continue to deliver superior results and earn the trust of practitioners and patients worldwide. [b]Improve Your Practice with Candela Quality[/b] GentleLASE PRO is faster, cost-effective, and easy to operate. With its Dynamic Cooling Device, it delivers among the highest peak power found on any hair removal laser for unparalleled treatment efficacy. The advanced technology and improved capabilities of GentleLASE PRO make it the laser of choice for precise, non-invasive treatments. [b]GentleLASE PRO Versatility[/b] Your investment in GentleLASE PRO technology will allow you to treat much more than unwanted hair. In fact, practitioners around the world are reporting on their success treating a variety of conditions.
1ReplyFri Feb 27 2026 | Screen backlight My device is a Candela Pro. The screen backlight is flickering. What could be the reason for this? Thank you. Reply |
1ReplyThu Feb 26 2026 | Screen backlight Merhaba, Cihazim Candela Pro. Ekran arka isigi titriyor. Bunun sebebi ne olabilir? Tesekkür ederim. Reply |
2RepliesMon Dec 29 2025 | Dcd canister Do we have to remove dcd canister everytime we closing the machine Equipment: Syneron-Candela - GentleLASE Pro Reply |
| Laser Type | Alexandrite |
| Height | 42.6 in |
| Length | 36.9 in |
| Weight | 237 lbs |
| Wavelength | 755 nm |
| Width | 19.9 in |
Repetition: Up to 2 Hz Pulse Duration: 3-300 ms Spot Sizes (diameter): 6 mm, 8 mm, 10 mm, 12 mm, 15 mm, 18 mm Fluence Range: Up to 150 J/cm2 Beam Delivery: Lens-coupled, 2.5 m optical fiber with handpiece Pulse Control: Finger switch
