Cynosure - Affinity QS
by Cynosure
Two Wavelengths-and Twice as Powerful
The Affinity QS is a high-powered, Q-switched Nd:YAG laser that lets you choose the most effective wavelength for treating multi-color tattoos and pigmented lesions: the 1064-nm wavelength or the 532-nm wavelength.
-TJ78
Fri Oct 27 2017
Service Mode
How do you get into Service Mode?Reply
-s90
Wed Mar 12 2014
red light comes up
energy alert wriiten  red comes up when i start the laser and light is yellow instead of green
[list]    [*] The 1064-nm wavelength is ideal for treating darker tattoos and dermal pigmented lesions, such as nevus of Ota or nevus of Ito    [*] The 532-nm wavelength treats red-colored tattoos and epidermal pigmented lesions, such as solar lentigines    [*] Two hundred percent as powerful as competitive Q-switched Nd:YAG lasers    [*] Optimal versatility enables you to switch wavelengths, select spot sizes (2mm, 3mm, 4mm, 6mm) for customized treatment and deliver more energy where it's needed for faster treatment of large areas    [/list]
Laser TypeNd:Yag
Height32 in
Length 27 in
Weight132 lbs
Wavelength532 nm and 1064 nm
Width10 in
