IRIDEX - Laserscope Gemini
by IRIDEX
Surgical Laser
The Iridex Laserscope Gemini is a clinically versatile, dual wavelength, non-invasive, fast laser that offers more than 25 FDA approved applications indlucing today's most requested treatments of permanent hair reduction, wrinkle reduction, acne, diffuse redness, age spots, pigmented lesions, telangiectasias and spider veins. Dual wavelengths include a 1064 Nd:YAG and a 532 KTP. The computer assisted settings coupled with the ergonomic lightweight handpieces create the perfect combination of an effective, yet easy-to-use laser.
0RepliesTue May 16 2023 | Error 86- Line voltage reconfig I am trying to reconfigure my Gemini Laserscope from 240v to 208v. I have flipped the switch on the back to 208 and have moved the labeled connection on the back right as well, but still get error 86. What other reconfig steps am I missing? Reply |
3RepliesSun Feb 05 2023 | Is the Gemini provide true long pulse or quasi-CW? Is it just a series of Q-switched pulses? Is 532nm different in that sense from the 1064nm?Reply |
4RepliesSun Sep 18 2022 | Problem 10 Our machine gives problem 10 error during selftest. Does anyone knows the solution of this problem? Decription of this error is low coolant level, obstruction from broken glass, pump thermal shutoff/ failure and pressure/flow switch failure. Where can i control?Reply |
| Laser Type | Nd:Yag |
| Wavelength | 1064 nm |
